steventux
Hi all,
I've recently bought an '05 Vito 109 cdi and the glow plug light comes on after starting (starts no problem) for 60 seconds then goes out. This doesn't happen on warm start.
I recently replaced the glow plugs with Denso plugs from a reputable supplier while I was servicing the vehicle.
The engine warning light came on after replacing plugs. It only comes on 30 seconds after the first startup of a 24 hr period.
My local garage diagnosed the fault code as the glow plug relay. They replaced the unit and the engine warning light is gone but the glow plug light still comes on for 60 seconds after starting.
In short I've replaced everything in the glow plug circuit to no avail. I've checked connections and wiring for signs of wear/shorting but everything looks in good order.
Yet to do a resistance test on the plugs but wondering if the light might indicate anything else?
