Phataardvark
Hi All
I am new to this forum so sorry if i have missed some resources somewhere that would help me, but i did look first.
So I will kick it off with my main question, I cannot find the correct fuse box layout?
I have attached a picture of what looks like the correct version of the fuse box which i found on a forum and may have the next page too but not sure but i need the following pages for the two sub fuse boxes in engine bay etc that match up with this version of the fuse box as any version i can find online is for a different revision of the fuse box and none of the fuse values match up so i doubt any of the fuse uses and numbers match up.
Next issue, my ignition switches on fine and dash all lights up, but I cannot turn over starter with the key, instead there is a badly rigged up starter button as well which needs to be used. Is it common for the EIS module to fail just on starter circuit, is it likely to be something else that caused previous owner to get this bodge done?
Alarm is troublesome, randomly goes off even if interior sensors and towaway are switched, switches seam to work as expected. Do I gather most likely issue is corroded or failed battery inside alarm horn, and do i gather this is inside passenger wing somewhere?
Dash screen panel only comes on when it feels like it but does have almost all lines working on it, is this likely to be dry joint or loose connection or is this just a sign the panel is failing, dont want to spend £60 on a new panel if i dont have to.
Finally my heater is completely dead, I have the full climate control with LCD panel and there is no function at all, no lights on buttons, no heater fan etc, temp always on high, is this likely to be dead controller, fuse, connection etc.?
Sorry to have so many questions, its just because I am new (and stuck at home)
