yes it was stuck on the side of the radiator.Just a poser was they fitted with an oil cooler ?.
TAKEN FROM
Pistons, Compression, Head Issues
Again dire warnings about not overheating these big bore engines and from the look of it headgasket shape may not be your only problem! piston height wrt deck and cam lift being others- I suspect also that many of these older engines are "compromise rebuilds " using non original spec parts because that's all that was still available at the time.
Again have you compression tested each cylinder.
Compression test is normally done cranking the engine over with the plugs removed ( so not started ) but it does need the engine to be built up with the head in place . The tester screws into the spark plug thread .Hi Qutsell
No I haven't compression tested the cylinders. I am waiting for a garage to get back to me regarding the work that needs doing to the car.
This is all new territory to me, so trying to do as much research before is gets out of control, and learning new things from the forums like this.
In summary what will the compression test in each cylinder do, and won't it have to be done with the car started ?
The emulsion has gone through the intake system as it has probably entered a cylinder and been pushed up by the piston with an intake valve open.I am still working out how oil as come out from the top of carbs .
I would go with it getting there via the crankcase breathers with the fluid volume in the CC being all the oil plus coolant.
If you're right - bent con rods?
Crewe Engines are the UK Mercedes approved Mercedes engine remanufactures .
They will either sell you an exchange engine , remanufactured as new , or if you want to keep your car as an original 'matching numbers' example , you can send your engine to them and they will rebuild it .
Just bear in mind they aren't cheap .
Crewe Engines Mercedes-Benz Vehicle Engine Remanufacturers Cheshire
Crewe Engines are the UK's leading Mercedes-Benz engine specialist. Remanufactured Mercedes engines are our specialisty with over 30 years experience.www.creweengines.co.uk
You could also try Dave Collins - from memory [email protected] as he is a specialist breaker and I have an idea he may have a good used example of one of these engines in stock .
