Servicepoint
My car has been garaged up for the winter and only periodically started over the last few months.
I noticed today when I started the car that the battery warning light was on. The car starts first time and the alternator belt is in place and not slipping. Some might remember I did have an issue with the belt slipping and was advised on here how to adjust. A couple of things now spring to mind, have I tightened the belt too much and destroyed the alternator ( I can’t turn the belt by hand) or has the alternator just failed?
I have the battery on charge at present to see whether this helps.
Not sure if this is related but the previous time of starting the car the brake wear indicator was illuminated on the dash, the pads are definitely not worn as I had the callipers off for refurbishing and the pads were as new , I assumed it was the wear indicator leads that were the issue as these are still original and I believe prone to failure? The two warning lights are side by side on the left of the binnacle.
Any advice would be appreciated.
