grober
MB Master
At that money the HELLA is probably an exchange reconditioned unit rather than a new one- nothing wrong with that, but the price may depend on return of the old unit
Thanks.I don't know if you have a circuit diagram simple enough to help visualise what might be wrong. Back in the days of a W123 charging systems were relatively simple and all much the same in principle. The most likely cause is a failure of the rotor to produce a magnetic field without which there will be no output from the stator.
From the diagram you can see that for current to flow through the rotor winding, it has to pass through the voltage regulator D+ to DF. Briefly shorting out D+ to DF will diagnose a faulty regulator if the alternator then produces output. Then current has to pass through the brushes so you need to make sure they are making contact with the slip rings on the rotor. Lastly it's possible for rotors to go open circuit which can be tested with an ohm meter. The resistance should normally be 2 or 3 ohms.
Less likely is a stator winding failure but if you can show there is current passing through the rotor then there is only the stator windings and diode pack to investigate as possible causes.
No it’s definitely new and still in the box. No return needed.At that money the HELLA is probably an exchange reconditioned unit rather than a new one- nothing wrong with that, but the price may depend on return of the old unit
Thanks Ted, I’ll give that a go.Looking like the alternator, I’m afraid.
It would be worth just checking that there is power to the alternator - there will be one or two thick wires- probably red - check that one of them at least has power with a test light if possible.
There is also a thinner wire - blue iirc - that is just the warning light wire (also provides initial excitation via the warning light) but as you say the warning light works there is unlikely to be a problem there.
The warning light should go out with ignition on (engine not running!) and that wire/plug removed.
Tested the wires at the alternator and there is power power at the red wire.Looking like the alternator, I’m afraid.
About 4 years now.Servicepoint Can i ask how long have you owned the W123?
The Hella one seems worryingly cheap. But a used one may have issues; bearing, regulator?My options now are
the new Hella at £95
A used Bosch at £119
Repair of my own at £??
The local place I know that does the repairs are excellent and I’ve known about them for about 30 years but they can’t give me a price.The Hella one seems worryingly cheap. But a used one may have issues; bearing, regulator?
If yours is the original, I'd be tempted by an overhaul by a VERY reputable operator. New bearing and regulator, etc. It may be worth Googling for a highly respected company that can rejuvinate yours.
I wish I'd done that but I needed the car on the road. Maybe I'll still get the original rebuilt.
Good hunting.
R
I don’t think it actually covers my engine type, 230ce M102 E23?Good, i like to know that it will be of use to you and everyone that needs it .![]()
Thanks, that looks like the one. Excellent.So i think its in this one just engine info Mercedes Benz Service Manuals dont worry now and then they ask for donations you can if you want but as yet i never have
