Good evening all. This is my first post here and I'm seeking a bit of advice.
I have a 1992 W124 230te which I have had for about 6 months. It's a lovely ride but has always had a buzzing noise in the boot which I assume is the fuel pump. I took it on a run today and drove 60 miles (motorway) without a problem but on the way back it started to hesitate and lose power. I slowed down and tried to continue on but it was very jumpy like it wanted to stall but would pick up again. When pulled over it would idle without issue, good oil pressure, temp gauge normal but same issues when pulling off again. I stopped for 20 mins and started off again and was ok for about 2 miles until the same happened again so I had to get it recovered. The car had the same issue in traffic about 3 weeks ago. We managed to get it home and was fine the next day and has been fine until todays run.
I suspect it is a fuel problem but am not sure what to check. The fuel pump is still buzzing in the boot but could this finally be on the way or would it work until it fails (i.e does performance of the pump degrade or will it just stop working)? It has been serviced recently and I have changed the spark plugs within the last month. Any advice would be appreciated. Many thanks.
