W124 '93 E320 Coupe fusebox wiring
scottan
London
C240 Sport Tip (gone) C124 E320 coupe
Am hoping someone out there has replaced a main fusebox before and has a photo record of which colour wire goes to which fuse. Or even better a diagram/map in colour?
Thankyou!
Number the wires with some masking tape and a pen, the box is already numbered underneath.
Thanks, was looking for something I can use to see if the wires are linked to the correct fuse...given the gremlins and the remediation I have carried out so far, I think they may not be!
If there is nothing out there i may have to find a fellow coupe owner and ask if I can take a look!
Sorry, I'm no electrician, and perhaps you know for sure that your fuse box needs replacing, but are you aware of the wiring loom issues associated with your engine? If not, you may like to search M104 wiring loom, just to make sure that this isn't the issue.
