W124 Air Con Problem
aybracers
London
C250Saloon,CLK320
Hi All,
I have a W124 220e 1993 model with factory (Non automatic) air conditioning.
If I start the car with the EC light lit(i.e. Air off) quite often I hear a clunk from somewhere in the dashboard and the the EC light turns itself off causing the A/c to start. I have had the system checked electrically and a couple of switches replaced(The high/low switch next to the A/C tank and the water temp. sensor next to the thermostat). The A/C works well when switched on but I still get this problem most times I start the car. Now it is becoming difficult to switch the air off - pressing the EC button does not immediately put the light back on. Is there some connection from the EC button to the vacuum system that controls the air flaps?
The clunk going from off to on is normal - it is the load of the a/c causing this - means the system is working. Normally the problem is getting the a/c to come on because of low gas levels - dont know the cause of the problem you are having - maybe something as simple as a bad switch contact in the EC button?
Maybe you should just leave the a/c on? It will last longer that way for the sake of 1 or 2mpg.
