W124 Aircon Not working
I can proffer some info on mobile A/C systems since i have been working on this stuff since I was about 18 years of age.
I am now in my Golden years and that means more than 50 years experience working on all types of stuff!, not just cars . I have passed by proctored exam passing EPA certification in the USA to dispense and repair A/C system for profit.
Now before we get to gauges a good A /C tech mechanic "feels up" the job!
Harkening back to me yunger yurs I apprenticed under a good master mechanic called Eric from Mevagissey. Ex Bosun Wartime RN he reminded me of the following.
Look m'lad always feel the system up like you wuz feeling up a nice looking woman in the pub. --Like when I wuzah went ashore!
The thin un's are hot, can burn yah--but the fat 'uns are cool & comfortable like and like being felt up unless something is wrong and they can burn yah too!.
Use this to diagnose A/C systems, that's how it done in the Royal Navy below decks! --Feel the pipes--the fat uns are cool, thin uns are hot!
Never forgotten these words of Cornish maritime wisdom!
Re-gas that's strange word to use!
T'was never used when I went to college in Gloucester & Chelt'nam --Recharge with refrigerant more like!
Yanks would laugh their heads off using that term in a shop! Latinos too!
Must be zummut to do with the EEC!:eek:
The reason is, that in some parts of the system its a liquid refrigerant and then in some other parts its in a gaseous state . If any of these conditions are changed then the system won't work properly!
Briefly the refrigerant leaves the compressor in a gaseous state, but flowing through the Condenser (keyword condenser--Condense ) it changes to a hot liquid! --How hot ? Well depends upon the air coming into the Condenser but there's a ram air effect when are driving the car and a fan sometimes to cool it if it start to overheat cos it can't reject heat fast enough sometimes !
Now the Yanks invented A/.C --a Mister Carrier no less ! They also invented R12 a lovely refrigerant. Why do I say that?
Well simply put whatever the pressure you read on a gauge on the HIGH side is the actual temperature of the refrigerant and in the LOW side when in gets injected into the evaporator=-EeH Vap o- Raetor suggest a vapor --it boils as a gas. The system pressure drops to about 18 to 22 DgF as it comes out of the expansion valve which is again the temp inside the evaporator ., That level of cooling or boiling refrigerant sucks the heat out of the cabin, then returns to the compressor as a vapor .
Generally speaking when talking of R12 the high side is 2.5 times ambient on a good running system and about 25 dgf is good on the low side.
Nowadays we use R134a which is a much less efficient refrigerant so it cannot reject heat as well as R12 . So expect to see about 250 to 275 on a fairly hot day and about 32 /35 on a gauge on the low side --feel the cold on the fat pipes! But be careful with the thin uns! The temp could be about 250 F
Can burn yah!
OK with that in mind
I will comment on a few overlooked things and might be able to explain what is going on the the inoperative system mentioned in this thread.
Tuercas Viejas
I had my E280 CDI recharged two weeks ago and during that time it got weaker and weaker until blowing warmish air, Kwik fit have today rOW e gassed and said no leak detected so why did it stop blowing cold air??
Does this pre test they do detect air condenser leaks? Obviously it's losing gas :(
The said run it for a few weeks and they'll have to have their master mechanic look at it and try and find what's the issue?
The most overlooked item on any A/C system is the charge valves.
On service and re-charge in my shop EVERY car gets a new set of schrader style valves. On most Benz's and BMW's they are disposable charge sockets. Average cost is $25 per line.
Also any car seriously down on a charge must be checked for leakage at the compressor shaft gland seal. As wear sets in, it will leak the residual charge through the seal to atmosphere. The only exception to this is the Prius since the compressor is a self contained electric style unit with no drive shaft of Gen2's and above.
As with any good system it will leak about 5% of the charge which is lost in any compressor per annum . As wear sets in the leakage accelerates of course. R134a being is a controlled substance and considered a greenhouse gas. Hene the reason for licensure to professionals in the business .
Tuercas Viejas
The OP lost me when ATS was mentioned for an AirCon recharge.
Why take your car to a tyre shop to have something as technical as its aircon serviced ?
I know a lot on here would have had their air con 're gassed' at ATS or KwikFit without incident. But when it does not work after that these places are stumped, they simply do not have the skills to investigate much further.
Had the wife's Zafira A/C vacuumed/dried/recharged, dye and pressure/leak tested last week at a local independent garage
£40 + VAT...shop around. help keep your local mechanics in business, you might need them ne day. :thumb:
I can only echo some of the advice above. When our 124 lost all its gas in Italy the local mechanic could not find any leaks using his automatic machine or dye test etc. They got an expert in who used some sort of electronic sniffer device and found that it was leaking from the charge valves - easily replaced - and also a little from behind the dashboard. This we have decided to leave for the time being and see how long it takes to empty again.
Thanks all, I took mine to Kwik fit, who recharge her free of charge and now seems to be holding the gas, I wont take it back there tho as I find some of their mechanics or shall we call them cowboys? very unfriendly and aggressive!
Will use a local mobile company instead and inform them of these charge valve suggestions from you good people.
In fairness , I have used Kwik Fit as a first port of call because of their " no improvement ( actually no reduction of 10 deg C ) ; no charge " policy , and if it fails within 30 days full refund .
Even though it's just a kid connecting up the machine , if something turns out to be wrong , it cost you nothing .
