W124 auto dimming mirror
This is from a member on here - 2phast.
Definitely interesting. I'm curious how it would look and work installed in a car and how much £?
Ive got them on most of my cars now... love them... I go for the version without the compass as that really does look a bit 80's jeep..
was it easy to install? no serious modifications to the wiring harness?
is there a version with map light? (just like W211 mirrors)?
in the clip they mentioned something about FM modulator,do you have it?
How about the bluetooth?
Takes a few minutes to install, the kit provided has everything you need... pull off old mirror, locate ground wire and ignition feed wire, hook up T connectors and thats it.
No experience with map light etc.. i just went for simple dimming ones for my W126's, W124 etc.
As above its very simple. The hardest bit is being brave enough to use the required force to remove the old mirror and insert the new. The spring mechanism is extremely strong.
