w124 e280 misfire sorted
smoothcoupe
WEST YORKSHIRE.
MERCEDES E55K-2001 AUDI S8-MERCEDES 300CE 24V SPORTLINE
the misfire is now sorted. i changed the 3 ht leads and plugs... but it still misfired. i then changed the first coil, it then started and ran perfectly...also can anyone tell me what the gaps on the plugs should be.. thanks.
Usually 0.8mm BOSCH plugs normally come ready gapped IFAIK but worth checking. Easiest source for these "legacy model" plugs is MB dealers. I have also used the appropriate heat range NGK plugs and found them fine. Don't be tempted by the newer multi electrode plugs- old MBs don't like them.
