Getting power to switches doesn’t mean there is power going to the motors so check fuses, usually both front windows are on one fuse and both rear windows are on another fuse.
Clean up fuse ends and contacts just in case there is a bad contact being made.
Ignore what I said about switches above, I may be wrong about that, from the diagram below it appears the left front and rear are on the same fuse. Did both windows faille at the same time?
Front and rear windows on separate fuses. They have never worked whilst I've owned car.i was trying to avoid stripping down doors but will have to so u can check power to motor.
