Hi all,
I am a proud new owner of an W124 300D (for about a month now). And its been used on a few trips of moderate distance so far without hitch.
Today on my way back from Winchester - I smelt a dreadful chlorine like smell - followed by a small stream of grey smoke emanating from around the central console buttons - actually right from around the airco and recycle buttons. I then saw smoke come from behind the rear window washer/wiper button. Smoke stopped - kind of - but smell continued..
Fortunately I was only 5 miles from home - so I switched off the blower and aircon and proceeded with care.
When I got home - I popped the bonnet - but didn't notice anything at first - all the visible fluid levels looked ok.
I then noticed a puddle had developed behind the front right wheel - with a fairly constant drip. Looking in the engine bay again I noticed a puddle of water underneath the brake master boost cylinder - and a wet area around some electrical component (looks like some sort of valve mechanism) - see photos. Dont know what this is but it was extremely hot - and had melted a plastic cable tie that was touching it.
I started the engine again - to see if I could locate the leak - and noticed smoke coming from the plugs on this thing..
So can anyone help diagnose whats wrong, what needs fixing - and whether I've fried my airco controls in the cabin? (The little ECO red light doesn't come on now )
Expensive?
Its booked into a Merc dealer for a oil service on friday - so I also need to know if its driveable..(to take it there).
Can I disconnect the plugs from the component I described above?
I've uploaded some photos - to help describe the problem
Thanks for any help
phil
Expensive?
Thanks for any help
phil
