rumelk
Hey Guys & Girls,
Got a bit of an issue with the 124. When i start it up, it constantly idles around the 1500-2000rpm. It started doing it very randomly, it use to idle between 700-1000rpm, which is what i thought was normal. However all of a sudden it just crept up to 1500-2000rpm.
The idle is not rough, but it car drive it self. I went down a straight road and it managed to accelerate to almost 30mpg without me even pressing the pedal. I did recently check the duo valve, so radiator pipes were taken out, could there be any sort of air leak which could have caused this.
Ive also checked the throttle linkage springs which seems ok, is there anything else i should be looking for?
