MB-tex
Hi All
My old 96 e280 5sp auto estate is now well over 300,000 miles and still going strong-ish. Still my daily driver and a rolling restoration when I can afford the next bit that needs doing. Have all the parts now for a total refresh of front axles, redid the whole rear subframe 4 or so years ago and had the rusty rear cargo windows welded up and rear section resprayed last year. Also head gasket 3 years ago. So in many ways she's in fine fettle apart from jacking points, inner front arches (2 old inner arches in shed) and an ongoing front end oil leak...
So onto the problem I am on here for help with. It is intermittent and my regular mechanic cannot figure it out, partly cos he couldn't get it to perform when he had it in... When I accelerate from a junction there is a (sometimes dangerous) lag before the power comes on. Its like the engine is holding its breath before it bursts into life again. It sometimes happens when accelerating when already moving along too. It is also often accompanied by a popping sound from under the bonnet that could almost be described as a backfire. It had new fuel filters 2/3 years ago. It had a new fuel pumps too around the same time. New fuel pressure regulator too. Spark plugs are all ok and air filter is pretty new. Dirty injectors? Wiring loom? Any advice gladly received.
Tom
Tom
