Bellow
Hardcore MB Enthusiast
I'd be more inclined to eliminate in entirety any possible fuelling malfunctioning before throwing money at a new loom.Sounds like as sticky throttle body plate- which might be dirty or more than likely the internal wiring is gone as suggested. your symptoms suggest increased fuelling without a corresponding increase in air flow=faulty throttle plate position signal to ECU
The symptoms are suggestive of fuelling issues. Either momentarily weak or as per above, rich. Reading the plugs would go a long way to pinning down a problem there.
If Grober's suggestion is correct, it implies a pretty robust ignition system - capable of firing what will be pretty wet plugs.
