D
Deleted member 11979
Guest
Evening,
The outside temperature gauge on my W124 has a fault.
When you initially switch on the ignition, for a second or so, the gauge displays the correct temperature, then drops by around 10 degrees.
It will still fluctuate correctly registering changes up and down by half a degree or such as the day progresses, but always around 10 degrees too cold.
Turning the car on and off does not sort the problem out, unless it's left for an hour or so, hen it will initially show the correct temperature again for a second or so.
Sensor, display or something else?
Any ideas greatly appreciated.
