OM606
Hi everyone, this is one of the annoying, quite hard to diagnose noise. There's a thud noise at the back of the car. At first i thought it was a bag of tools left in the boot. It's bad when driving over pavement or a rough surface with gravel or some of the very patched roads we have here, particularly when driving slow. It almost sounds like i have a trailer behind the car. Dampers where shot, i replaced them, the car drives smoother but the noise is still there.
I've asked someone to shift the transmission between R, N and D while i was under the car and out of four subframe bushings, i was able to see a slight movement in one of the front ones. The differential mounts aren't cracked or squished but it was tilting a bit either way between R and D, is this normal? Inner control arm bushings are thin but it seems like they are perished, the bolt going through is quite rusty as well. Other bushings look fine. The car drives fine, accelerates straight, brakes straight. However, i think that it doesn't feel as smooth as is should.
If you have experience with the kind of issue with the W124, please chime in!
