W124 steel wheels
D
Deleted member 11979
Guest
Looking for a set of 4 or 5 W124 steel wheels, 6.5j x 15
No tyres required, thanks a lot
I have a set 4 w210 steel wheels you can have. They are 6.5j x 15 et 37. They have are genuine MB with a w210 part number, and 1 has a a bit or curbing, but it still holds air o.k. I also have a set of matching wheel trims which could do with tarting up, and a full set of genuine MB wheel bolts for steel wheels. All yours for free if you can pick them up, or get a courier or whatever to collect. Located in Swansea, so if you're in Ilfracombe send a boat over and I'll bring them to the marina!
That is really kind of you, thanks very much, I'll check the offset for a W124 and PM you.
I'm afraid my yacht is out of action at the moment, so I'll have to send the helicopter!
I have non damaged 4 steel wheels that came off my 1995 W124 E220.
I also have the original wheel nuts and a set of plastic wheel trims of same circa.
I live in Taunton - interested?
Damn... I can't even give these steel wheels away for free!!! I'm determined not to put them in a skip, but I'm running out of space.
I can see the North coast of Devon from my living room window but can't throw wheels that far.
I wonder if inflating some rubber bands around them, lets call them rings, and filling them with air would enable them to float?
