punjabi
Since about a year now, the 300TE Auto had developed 'delayed' gear changes and slight 'jerky' changes. It has done around 197K miles. Took the car for an MOT a few weeks ago and mentioned the tranny 'problem' to the mechanic just to get an 'opinion' from him. Although it passed the MOT with flying colours, the mech stated that the tranny may be knackered and should be replaced. With a bit of skepticism on that comment, I decided to give the tranny an oil and filter change. Quite an easy task. Drained the oil (3.5l), dropped the sump, replaced the oil filter (3 screws) which was almost blocked solid with 'gunge'. Didn't bother with the oil from the TQ as to much bother turning the engine to get to the drip bolt and evening was closing in! However, put in same amount of oil as came out (MB ATF OIL) and lo behold...............the tranny is now as smooth as silk, absolutely fantastic - these models are engineered like no other! Guess, it was running on the factory oil and filter for 197K miles!
Always try an oil and filter change before condemning the tranny!
