shanksy
Hi all,
I will be finally undertaking the install of my heated seat wiring harness this weekend.
Being a bit wet behind the ears when it comes to electrics i've done as much research as I can but just wanted a bit of advice on where a couple of pieces of the harness go.........
I need to know :
a) Where the backlighting connector is expected to connect to
b) The best route for the 12v feed to go through the firewall.
c) Once the loom is in, can I join the wires from the new carbon pads up at the point where the seat connectors are ? The wires into one of the seat connectors has 5 wires; 3 x Blue/Black, Brown/Yellow and Brown. Which of these wires would I use ?
I've attached some pics of the harness and the connectors/wires.
Appreciate any help
Cheers
I need to know :
Appreciate any help
Cheers
