W126 wont start
S11YBM
East London
83 500SL, 84 500SEC AMG, 84 500SEC, 84 500SE AMG, 97 CL500, 04 CL500
The car wont start :( When I try to turn it on, the car wants to start but it doesn't. The other day I did changed the distributer cap and rotor, but it did start ok for a few days after. But now nothing. The last time I had it on, I did push the accelerator all the way down in idle, but I don't see how this could cause it not to start.
I've jumped the fuel pump and the pumps work, I've checked all the connections on the distributer. any other ideas?
My old 420se 126 used to not want to start now and again. Switch on ignition and have someone stand at back of car drivers side, you should hear the fuel pumps prime up, if you don't it won't start and is the fuel relay switch.
im assuming that you have the older type of cap with the pronged clips, its possilbe that the cap wasnt on correctly and when driven/revved the cap may have moved. (had this on my 190e) or you may not of correctly placed the rotor.
just work backwards on the parts you have replaced before the starting issues occured.
A few simple tests should point you in the right direction .
Do you still have the old distributor cap etc ? In particular look at the carbon brush in the centre of the cap as these can break easily .
It's worth just popping the old one back on ( assuming the car was running OK with it ) and just see if it makes a difference .... just because a part is new does not guarantee it is fault free , the new one could have cracked or failed some other way ....
Do you have a spare spark plug ? Put it onto the end of one of the ignition leads and ground it against the block , then see if there's a spark when you crank the engine - this will tell you whether the ignition is working or not .
If no spark with the plug at the end of the plug lead , take the 'king' lead from the ignition coil and put a spark plug onto it , repeat the test . If you then get a spark there is a problem with the distributor cap , if still no spark , suspect the coil , or worse the EZL unit ( expensive ) .
On the other hand , if you do get a spark at the end of the plug lead , the ignition system most likely is fine and you are looking at , in all probability , either a fuel problem or a vacuum leak .
A very simple test to start with is to remove the cover of the air filter housing , get an assistant to crank the engine and watch the disc above the throttle body , if vacuum in the induction side is good , it should be sucked downwards as the engine turns over - if you don't see the drop , look for a pipe off somewhere on the induction side .
Assuming vacuum OK , and you have already checked fuel pumps running , you want to check fuel delivery - you can do this by loosening one of the pipes on the fuel distributor and get an assistant to MOMENTARILY turn on the ignition - fuel should squirt out - on a cold engine a very small amount will do no harm and will evaporate quickly - if no fuel , you have a problem somewhere in the fuel system .
Thanks all for your responses.
@markhgg - The fuel pumps can be heard working.
@optimusprime - Yep, I jumped the relay at pins 7 and 8, fuel pump kicked in, but still didn't start
@psa & @Pontoneer - I checked cap, and even put the old one and rotor back on, and still no joy. There is a spark, but I only checked one of the spark plugs, will check the others tonight. Could even one dodgy connection between the distributor and spark cause this kind off issue? .
I'll also give the simple vacuum test a go too. A stupid question, but what side is the induction side?
I tried to loosen one of the fuel lines, but they seemed pretty tightly on, I didn't want to apply too much pressure and break something. I'll spray some wd40 on it and try again.
Would it be worth trying to spray some starter fluid under the big disc and see if it starts up?
Ok so I have some success! I cleaned out 4 of the 8 spark plugs and it fires up! I bit shaky but it starts!! It shows you should check for sparks on all the plugs! So I'm going to order a whole new set of sparks. Any brand recommendations?
Just make sure you get none resister plugs.
Thanks for the tip! Are Bosch ones any good? In EPC they have 3 types, ones with quad electrodes, ones with platinum and ones that seem standard...
I'd just go with the standard copper core ones from the dealer.
That's the best bet. ECP, GSF and the likes will happily sell you resister plugs, as they tried to do with me. I explained why they were wrong and could potentially damage the ICU £££££ ! They simply maintained the resistor plugs were correct for my car, because that's what the computer says and they no longer stock none resister type. :wallbash:
Yeah I think it's all about sales, rather annoying!
I ordered 8 plugs for £23! Not bad considering they are guaranteed fit!
I was going to get some ignition leads too, but they come in separate pieces and need to be built up! Not sure I've the right tool to do that. Any one recommend any pre-made ones?
Bit late but I ordered ngk bp6es plugs. 7mm magnecor leads from eBay which take 3 weeks to arrive for £160. Or Chaz at sec shop sells a set which look OEM for £80
Thanks for that...I'll check out those leads!
