westberliner
Hello togehter,
we have here a W164 with H7 lights, it´s not the burner, I want to retrofit Xenon with Active Curvelight.
I bought already:
2x Xenon headlights
2x Leveling sensor for the front and rear axle
1x Control Unit for automatic high leveling
Now, I try to understand the electric plan of retrofitting.
E1/E2 are the headlights, there should have already not changeable connectors from the H7 headlights.
N71 is the additional control unit for high leveling.
Pin 19: F4- Connecting to SAM rear on fuse 54.
Pin 20: Connecting to ground (or it´s mass in english?)
Pin 1: Can high (should find the co-driver connector with same colored wires)
Pin 2: Can low (should find the co-driver connector with same colored wires)
Pin 7,5,8,10,6,9: Directly connected to the leveling sensors
Pin 4: Connecting to the connector between the co-driver-room and engine-room (X25/2).
Pin 4 is my problem for understanding/reading correctly the wiremap. In the co-driver-room there are 3 connectors, I don´t know wich connector with wich pin I should connect the N71 ECU. Maybe someone can help me, to find the right connector?
Thank you very much in advance.
I bought already:
2x Xenon headlights
