W202 alarm going off still after new siren
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
Hi w202 1998 c43 IR key
Fitted new siren , after 30 seconds alarm goes off can lock the car as key wont turn drivers door
I have the two v shaped detectors on both inner pillars
Any ideas on what it might be
A battery on its way out can cause all sorts of problems. My old W202 suffered from an intermittent cruise control and the alarm sounding when it felt like it until I changed the battery, then all was fine.
How many times do the hazards flash when you lock the car...2 times or 3 times?
Is the siren new or used?
Dec
Ill check tomorrow on how many times it flashes
I found both internal alarm motion sensors had be unplugged they Are now connected the alarm still goes off but now takes 60 seconds not 30
Why would some one do that I don't know
It flashes 3 times to close once to lock
I had it on star today
If the hazards flash 2 times when locking means a door is not closed properly or a faulty door switch, that’s why I asked.
Alarm triggers;
4 door switches.
Bonnet micro switch inside bonnet lock… see HERE
Boot light switch.
Anti- towing sensor beside jack in boot… can be switched off at dash switch.
Internal motion sensors… can be switched off at dash switch.
Bad car battery, not holding charge.
Faulty siren.
Dec
Thank you I had it on star it looks like the towing sensor is faulty
I switched off via star alarm now working ill replace In weeks to come
Think you for all your help
Trev
