w203 ashtray removal
thanks dont know if has changed since facelift but after lifting gearlever suround i'm stuck
cant lift aluminium around gearlever or see any ashtray clips
Its exactly the same , open the ashtray , pull the aluminium lip towards the back of the car and this should reveal the underside of the gearbox ( gatier) and it will also let you see the ashtray lip.
On the centre of the ashtray lip , you want to pull up quite hard and the clips will free themselves. Its quite tight , don't worry about breaking it. it will come away , but remembering that the 12v socket is still attached if its the facelift.
I know its identicle on the facelift as ive just done it to my facelift car on sunday
thanks worked a treat
bit nervious pulling trim though
hehe , i know the feeling.... soon goes tho :)
Cheers Fuzzer,
I just searched and found that this was the answer to my problem also !!
Cheer m8
Have a nana and a rep!
:bannana: :bannana:
pacemaker..... what size is the satnav unit u are going to fit?
i have a CLK and want to put my DVD player into the ashtray if possible but its standard DIN-SIZED.......
