Hi - I bought a 2004 C200 CDI auto (with newer style interior) around 3/4 weeks ago. Since then it has been an uphill battle
When I got it I soon discovered that it was very smokey, and it would go into limp mode almost every time it was driven for more than 10 minutes. I cleaned the EGR valve which was definitely sticking and gunked up, but the problems persisted.
I have taken it to a local independent, and so far he has done the following:
* Intake manifold removed, cleaned and butterfly valves removed
* New fuel filter
* New glow plugs
* Replaced (fuel?) quantity valve from another car
Apparently the car has been put through numerous STAR diagnostic tests and everything, including the injectors, look fine. Also the MAF is reading correctly I am told.
No codes are registered when the car goes into limp mode. I drove it last night and it doesn't smoke the way it used to, however it limped after around 15 minutes of driving (limited to 3000 rpm).
So the question is, what is next? Could a blocked DPF be causing this? I have attached a photo of what I believe to be the DPF, am I correct?
Thanks in advance.
* New fuel filter
* New glow plugs
Thanks in advance.
