Fully serviced the car @ 70k - including new F**M fuel filter (big mistake as running perfectly in 6 months since purchased - should have just changed the oil and filter and left it at that!)
Drove 200 mile trip - no problem then drove to shop, bought stuff, came back, started car , engine ran for ~ 30 secs and then just stopped (no coughing/spluttering etc. - just stopped) and despite vigorous cranking, would not / will not even try to start
Investigations to date:-
- on cranking engine, noted fuel line to lift pump mt!
- removed new filter - solid! cannot even blow through it (collapsed medium?)
- Lesson - only buy OEM service parts for your engine!
- replaced new filter with even newer OEM Bosch from ECP + new MB pipes to/from filter
- crank engine - fuel lines now full (and fuel leaks from injector if cracked) but will not start (therefore lift pump at least OK?)
- ordered MB service kits for HP pump and rail pressure regulator - will fit at the weekend and hope for the best
Any other suggestions welcome
Regards
