W203 M271 Kompressor change
sam0229
Hi there
I've got a W203 C180k with 130k miles on the clock. The supercharger is not starting to get very rattly and noisy, hence want to change this and also the breather pipes beneath the Kompressor as idling is sometimes erratic
I would be grateful for advice as to whether this is suitable for a DIYer mechanic and any tips/documents/advice you can offer. I understand you have to remove the airbox and air inlet manifold to get to the supercharge
Many thanks
Sam
Are you sure its the supercharger and not the infamous M271 timing chain gear worn out?
Does it sound anything like this?
Timing chain already done at around 100k - no issues then but had it done as preventative
Have shown it to indy who confirmed noisy kompressor. Want to have a go myself if possible. Also want to replace the breather pipes beneath sc
^ That is good that the chain has been done.
If you are going to replace the s/c this PDF may help.
Perfect that's really helpful. Thank you!
Any information on how to change the breather pipes?
How much time would you set aside to do the whole job as a DIY?
I've never done this job and don't have an M271 engine, but again youtube has come to your aid,:D
That guy certainly loves using his pointy hook thingy! :rolleyes: Singular omission from the start :eek: disconnect the battery negative terminal before removing half the engine electrical connections! Looking at that procedure video I would venture that's a job best entrusted to an MB specialist. Factoring in labour and the cost of a new kompressor you have to seriously reflect on the overall cost of such a repair on a 10 year old car with 130K on the clock . There may be other options??:dk:
