KevinH2000
I've been studying the information and components I have acquired to this point and this is my present thinking.
The wiring under the seat is significantly different in the non-memory seat cars. This is a picture of the non-memory component of the wiring connections under the seat of the donor car:
The yellow connector is for the air bag system. I need to determine the purpose of the blue connector.
This photo shows the under-seat connections of Jake's car (Jake is a fellow W203 owner I met through the MBWorld forum) which has the memory function:
Note that one of the connection points is unused
This is a photo of the wiring currently under my seat.
I should not have to touch the air bag (yellow connector) and I will need to switch the black connector at the left to the memory module in order to provide power. Note that I had to graft the connector for the C63 (W204) seat power onto my wiring harness, but the W203 connector still has power. I can remove the W204 connector after I'm sure I can make the memory work.
This is a photo of the seat control module with the wiring I removed from the donor car.
Note the information under the bar code:
It appears that the CAN Bus connection is in the large black connector.
In order to connect the memory function to the seat I will need to find a wiring diagram for the seat module and:
1. Determine which wires in the large black connector are CAN High and CAN low.
2. Determine what the blue connector does and if needed how to connect it to my seat.
3. Whether I need to connect any of the other wires. They may send messages to the steering wheel and mirrors. If that is the case, I may not need to connect them.
There is a CAN block under the dash on the driver's side that I can use to connect the CAN wiring.
I may return to the donor car to harvest part of this.
I will also need to activate the system using DAS. Fortunately, Jake and I have joint custody of a system and I've seen the menu showing the activation screen.
Here's the system in my car which currently does not memory seats operational:
Note that the Driver Memory Seat Function is set to "Not Present."
Here's the reading from Jake's Car showing the Driver Memory is Present.
Again - Any insights on the wiring will be welcome. I think I am getting close to understanding how this works, but I still have a gap in my knowledge.
