Mikeyg360
Afternoon all, new to the forum and was hoping for some help.
I drive a 2011 W204 C220 and I've got a wierd problem with the front passenger side indicator, when you turn the ignition on (ie engine not running) indicators all work fine, no errors on the dash, but when you turn the engine on and go to use the passenger side indicators, it ticks once normally, then quickly (as if an indicator bulb had blown) with a bulb warning on the dash saying "front left indicator", weirdest thing is, the indicators are all working fine on the outside and flashing at a normal speed. It's got the LED indicators so can't be a blown bulb.
I've cleaned up the connections and checked for bent pins and what not, all seem fine.
Any help would be greatly appriciated!
