One for the W205 owners - any of you had any rattles from the rear like the below?
From the clip, you can hear the rattle most clearly between 2-6s then 8-12s 16 and 22s as I drive down a local road. There's a little noise from the mobile phone holder but what you can mostly hear is the noise.
Video including vibration noise
Car has been to Mercedes ( had two new rear shocks, one was blown and could be knocking but wasn't it ) and a local Indy and they tried tightening up the boot lid fit (Indy) and some panels below the rear seats ( Merc ) but that hasn't cured it. I did take the plastic covers off the lower suspension arms too but that didn't help either.
I've had it up on jacks and had a good look around but didn't see anything obvious. Sounds to me a bit like plastic/metal especially as it 'vibrates' going over bumps. Apparently drop links etc all under the car are are OK, have removed everything from the boot etc. Are there any common known areas to check?
