W210 cooling fan
davidjpowell
Doncaster
E350 w212 and Ford Ranger
Right seems to come on first, left seems to come on varying in speed, presumably as required
Is this right?
Regards
Da
Da
Right is driven by the electric motor...left is driven by a belt to the right. Belt is off or broken.
Pop off the black grill and look down behind the fans.
Mine has always been off...never made a difference. They are to do with the air con...not engine cooling.
So it is. Bugger
Does not look like a big job, slam panel being the biggest pain?
Cheers
David
I don't think it's a big job...but I never bothered.:o
In fact I did remove the unbroken belt from behind the fans...so must be very easy to put a new one on.
Will be towing soon and concerned about the extra stress.
Might be one to order the part on and do when have a spare couple of hours....
Pig of a job. All went well until the connector seized and came apart in pieces. Emergency trip to Halfords and new connectors in place and all tested.
ETA - Old belt in one piece at the bottom....
