Marty280
Merry Christmas everyone!
I need urgent advice and your input is greatly appreciated.
I have recently ( October ) purchased another 211, a 07 reg 280CDI Sport.
Apparently it had just been serviced and had a transmission oil change but it was leaking fluid from the transmission so I took it to my garage in Ealing Conor's Car Center and had it fully serviced straight away.
Now six weeks later the following problems are showing:
Car gets stuck in second gear sometimes
Jerky gear changes when cold
When starting in the morning car will barely move for the first 500 yards while revs can be as high as 3000, the suddenly it will engage and from there on it will get better until engine and transmission are warm. It will shift jerkily when driving around corners though.
I had it hooked up to the diagnostics yesterday and two fault s came up - turbine speed sensor and gear implausible or transmission slipping.
I'm extremely worried I called Terry at Wayne Gates but the earliest I can see him is January 7 and he is far from me, I'm near Croydon.
Here are my questions:
What did you think is the cause of my 7g issues? Conductor plate and valve body? Or worse?
Anyone knows where to get help before Xmas ?
I'm depending on my car and am extremely grateful for any input !
I'm reading though the forum/s as we speak and trying to understand more about the issues around 7g but let me know your thoughts.
Cheers
Martin
Cheers
Martin
