Doesn’t the bulb remain in the silver metal base . Check what a new D1s looks likeHi guys, need abit of advice
Ignitier came out with bulb, couldn't see anything, im thinking taking the front wheels off and arch liner to get it replaced that's if i haven't broke it
How would i get the bulb out of ignitier?
I did them both from the top on my facelift W211Will take wheel arch off over the weekend and sort thank you lads
Im prettyIt does , it’s part of the new bulb . I just looked at eBay .
Yup, new pack has the ignitiers attached, however there is no way to replace from the top, nearside maybe, but I think wheel and arch linner off is my best way to get access. If anyone here has a easier way do let me know, car is a w211 2007, bi xenon, main beam and h7 for the high beams, those should be easy enough to replaceIt does , it’s part of the new bulb . I just looked at eBay .
How did you get to the driver side with the abs pump in the way? Basically your kinda doing it blind. So just attach the black plastic and push in and clockwise, I can't see i side if there is a spring holding bulb, unless the plastic ring is the holderI did them both from the top on my facelift W211
Ill read your thread, just seen the link. Thanks.I did them both from the top on my facelift W211
Yep , it wasn’t easy buddy . If you know someone with small hands , get them involvedIll read your thread, just seen the link. Thanks.
So definitely no access if i remove the wheel arch liner?Yep , it wasn’t easy buddy . If you know someone with small hands , get them involved
I didn’t even think of that buddy , everything I had read showed it possible from the top which is what I did .So definitely no access if i remove the wheel arch liner?
Good job buddy , bet you have a few cuts on the back of your handManaged to get in and do driver side blind, from top, wasn't easy, nearside has more room that wasn't a problem. I decided against doing the high beam ones, too cold out, at least i can see the road now at night. Was a nightmare on m6 with one headlight.
Thanks for all the advice guys, it's appreciated
Yup lolGood job buddy , bet you have a few cuts on the back of your hand
