These bolts are usually fitted to correct the camber or caster angle and should be fitted whilst monitoring these angles on a wheel alignment setup, all 4 shouldn't be changed if not required.
These bolts are usually fitted to correct the camber or caster angle and should be fitted whilst monitoring these angles on a wheel alignment setup, all 4 shouldn't be changed if not required.View attachment 144320
