millo777
- Mar 9, 2011
- Location
- Swansea, Dubai, Riyadh
- 1997 W140 S600L/2003 S211 320cdi
My 53 plate w211 (Om648, 722.626) has suddenly refused to move anywhere. Was absolutely fine on Tuesday, no transmission noises, clunks, slipping or any other hints, but Wednesday it moved forward just enough to get out of a parking space then refused to go any further.
Engine is running fine, and gear selector seems to engage drive and reverse ok.
When I get in the car, it will initially move a few feet, then just rev freely as if the engine is under no load. Based on that, it seems the gear selector connector is still intact.
It's currently parked on a hill facing downwards so fluid levels are impossible to read properly, but there is definitely trans fluid in there, but it's reading way to full presumably due to facing down hill. The fluid also seems to be a yellowish brown colour which can't be good.
The coolant seems to be in god condition with no oil in it (I thought it may be a Valeo radiator victim).
Is there anything else I can check before handing it over to an indie for star diagnosis etc?
Thanks in advance for any help.
