Hi all, thought I’d give an update, I’ve had the car just over a year now. Have done a few things recently. I’ve more or less copied this content from my readers’ cars thread on PH, there may be some useful stuff here for other W211 or 55K owners.
It was originally a £68,000 car, so even though it’s now a 15 year old £6,800 car, the running costs are going to be... sufficient, understandably.
MB Medway, and Mike in particular, have been excellent since it first went to them a year ago on purchase. I’ve had a list of jobs to work on- which has really meant them work on- and with the exception of running down the battery sometimes when left for a week or more, the car has been great (and I think I have this one on the way to being solved). They had an SL55 in for some work too, in fact, Mike had read out the error codes and complied a job list and it had more than 10,000 errors and problems...
Last week, Mike changed the idlers, belts, water pump, supercharger bearing, all of which were past it at 135k miles. Once everything was stripped down, he found the the air conditioning compressor was also on its last legs- sent me a video of it, and we decided it would be mad not to replace it while everything was in pieces. A Mercedes one was something like £700, so a Behr one was sourced, for half the cost. It turned out to be a Mercedes one with the sticker removed- bonus!
[img]https://thumbsnap.com/s/DceiuN19.jpg[/img]|https://thumbsnap.com/DceiuN19
[img]https://thumbsnap.com/s/srQKsZkD.jpg[/img]|https://thumbsnap.com/srQKsZkD
[img]https://thumbsnap.com/s/apBijSin.jpg[/img]|https://thumbsnap.com/apBijSin
[img]https://thumbsnap.com/s/B7A9noc5.jpg[/img]|https://thumbsnap.com/B7A9noc5
[img]https://thumbsnap.com/s/goyVoPxa.jpg[/img]|https://thumbsnap.com/goyVoPxa
[img]https://thumbsnap.com/s/4nvqi8D5.jpg[/img]|https://thumbsnap.com/4nvqi8D5
[img]https://thumbsnap.com/s/C74VZ9jn.jpg[/img]|https://thumbsnap.com/C74VZ9jn
[img]https://thumbsnap.com/s/4YXYrMNE.jpg[/img]|https://thumbsnap.com/4YXYrMNE
[img]https://thumbsnap.com/s/WZ6suFdk.jpg[/img]|https://thumbsnap.com/WZ6suFdk
[img]https://thumbsnap.com/s/ReBzaygh.jpg[/img]|https://thumbsnap.com/ReBzaygh
[img]https://thumbsnap.com/s/881RTx4A.jpg[/img]|https://thumbsnap.com/881RTx4A
[img]https://thumbsnap.com/s/r19d4Rwx.jpg[/img]|https://thumbsnap.com/r19d4Rwx
[img]https://thumbsnap.com/s/4jbr6Sst.jpg[/img]|https://thumbsnap.com/4jbr6Sst
£700 Mercedes AC compressor
[img]...wi18.jpg[/img]|https://thumbsnap.com/kekjwi18
I decided to change the coil and leads for cylinder 7 myself, it looked like the easiest job on the list. Mike said the engine has to be fully hot to have a chance of getting them out, so that’s going to be fun. Notice it's happening in the future rather than completed. Probably a 3/5 spanners job for me.
At my level of spannering, I did complete the new plastic boot edge thingy with new clips. Thank you, BolideMichael for the offer of the clips. I have a small supply myself now. Which means I can find other 1 spanner tasks to complete around the car.
Inside the car, my wife has asked for a longer recital of my E-number BMW talk as a regular feature of longer journeys. To facilitate this, we relented and have set up two iPhones with headphones for the junior progresses in the rear. To meet their fidelity standards, I searched for some window blinds, I'm always, always tempted to retrofit these on our cars, but for £100 I put "laitovo" ones in, which clip into place inside the window aperture. The kids appreciate them for their delicate little eyes and the quality of their film watching on long journeys. I didn’t use the matching rear window blind as that’s a bit gangster for me- and I'm used to the BMW roller one.
Then, I bit the bullet on what is something like a £1,500 job at MB Medway or anywhere else- the SBC unit. My car somehow has counted 600k brake presses, when they typically go out of service at 2 or 400,000. So it's something that absolutely would let me down in Bordeaux on a French national holiday in August. After some research, I found John at ecu-repair
Mercedes Diagnostic | London Auto Electrician | BMW, Audi SBC repair in Mitcham for a refurbished SBC unit. I liked this guy. He taught himself how to refurbish the pumps, after his failed. I waited while he rebuilt mine including some preventative work on its ECU. It was cleaned up, reinstalled and the brakes bled. The caliper bleed nipples were all rusted and looked as if the fluid hadn’t been changed in a very long time.
[img]https://thumbsnap.com/s/fCckt1p6.jpg[/img]|https://thumbsnap.com/fCckt1p6
I haven't yet had the red message of doom except due to battery issues, it only appeared here because the SBC had been removed, which makes it slightly less functional
[img]https://thumbsnap.com/s/3UKcBNiV.jpg[/img]|https://thumbsnap.com/3UKcBNiV
[img]https://thumbsnap.com/s/ok9db2u4.jpg[/img]|https://thumbsnap.com/ok9db2u4
[img]https://thumbsnap.com/s/9kwXkm7J.jpg[/img]|https://thumbsnap.com/9kwXkm7J
It’s a very reasonable service, is good pre-emptive work done and I like the ability to rebuild components not simply throw modules away and replace with new. While I was there I had a new key from him, it’s one of the chrome sided ones from the facelift W211 and a bit more weighty, and a lot more presentable. My kids are massively impressed with it. Almost modern, Papa!
Sad, early 2000's Dad key
[img]https://thumbsnap.com/s/Pbpp7ywi.jpg[/img]|https://thumbsnap.com/Pbpp7ywi
Posh mid 2000's Dad key
[img]https://thumbsnap.com/s/xsRSeFZC.jpg[/img]|https://thumbsnap.com/xsRSeFZC
I'm driving it a bit, and fiddling with the wiring under the seats to remedy the battery drain. I'm fairly sure it's due to the seat modules not fully going to sleep, and that it can be rectified by replacing the modules, or by splicing the constant power to the seats into the switched power wire. There are many videos and guides to doing this, using a little plastic tap connector, but my wiring is different from the W203 Mercedes usually seen in the guides- my switched and ground wires are very weedy, with a more beefy constant wire... so I'm uncertain about cutting and splicing a big wire into a thin wire. I never completely finished my automotive electrician course, so I'm pausing before setting fire to anything.
ETA I’ve not been fiddling with the seat wiring while driving!
