W1ghty
There was a time MB embraced that dream (or at least to get the car out of warrantyThere is no such as lifetime oil.
No atf contamination on 7gI had a C320 CDI that didn't have the 2nd to 1st shunt. If it did it was very discreet.
But I seem to remember reading that it wasn't uncommon, and MB had software updates that attempted to resolve it. Some time successful but not always. Anyone else remember that from 10 years ago+?
Is yours facelift? Some earlier motors were known for a coolant contamination issue, but I would have thought that the pre 7 speed boxes.
Otherwise ATF service at 40k miles as said.
Sealed for life just means a shorter life.
Mb lifetime = while still under warrantySealed for life means until it breaks then it's life is over
Nice job buddy .hi all, It`s report time. Went to see Welvyn Merx on monday for a gearbox oil change. What a difference it made to my car! i fully recommend these guysso yea gearbox service is a must.
Hi Larkone, i really appreciate your very very helpful comment. Helped me big times to make the decision on where to get it done. Can you remember how much you paid roughly? It`ll be a good day out for meI live just over the border in N Essex and I go to Chesham because they were the only ones who properly sorted my pulling to the left. You really only need to do it once because once they have set it up correctly (Camber, castor and tracking) you will have a printout of the correct settings for your car that you can use at other places should the tracking go out - potholes etc. The issue, as you have found, is that most tyre places will only setup according to manufacturers spec and that is not necessarily correct for your car after some years of being bashed and twisted by UK roads.
My tyre wear has been absolutely correct since WIM (Blackboots) did mine (added 3 camber adjusting bolts) and have since used some local garages with those settings and they still work fine.
It was a while ago but all 4 wheels and 3 MB bolts fitted was around £160Hi Larkone, i really appreciate your very very helpful comment. Helped me big times to make the decision on where to get it done. Can you remember how much you paid roughly? It`ll be a good day out for mei will report back when it`s all done
Thank you very much! Have a good 1 all!
