The front bushes can be done without dropping the rear subframe completely. It helps to disconnect the propshaft from the differential. You can then drop the front bit of the rear subframe sufficiently to get the bushes out. There are a couple of nuts that sit into moulded recesses in the
fuel tank that you need to keep an eye on as you lower it down.
