w211 vibrating
parkscon
margate kent
mercedes 320 cdi avengard
Hi everyone I seem to have a problem with my 2004 w211, when I am at low speed ie 15-20 mph I seem to get a shaking vibrating coming from the rear this is especially bad when driving up a slight slope on a left hand bend does anyone have any clues what I'm looking for? :doh:
Check all the wheel bolts are tight
Strange speed to have problems. Suggest maybe check prop shaft for debris . Jack up wheels and spin by hand and look and listen. Swap fronts to rears if same size.check calipers and discs for debris
thanks I did wonder about the propshaft bushes but not sure what to look for when I'm under the car may well jack it up tomorrow and have a quick look.
Maybe worth making sure the tyre is not out of shape, and the alloy is not buckled.
