Kirkmeister
I posted recently about an unusual noise coming from the drivers side of the engine bay, thought to be a gearbox related issue though there are no gearbox problems.
I've attached an audio file recorded from the front drivers wheel arch.
The noise only develops after an hours running, and only when you move from Park or Neutral into D or R. It stops after you break 15mph.
If you can play the audio file it sounds as if someone is bouncing on a chair to make it squeak. The car is not moving though and the steering wheel is straight.
There has been a suggestion it could be connected to the eco boost pump as part of the stop/start system which is why it kicks in at low speed.
I cant afford to have the gearbox stripped to inspect (which has been advised by my independent garage) if its not a gearbox issue.
I'd be grateful for anyone that can run the file for any thoughts. The car runs faultlessly (96k miles) but I'm sure something is failing.
Many regards
David K
Many regards
David K
