W212 E Class 2016 - Boot not closing fully
MTWorc
Worcester
E220
The boot will close most of the way and will lock but the final “pull down” of approximately 5mm no longer works. I have read this is down to the vacuum pull down having been disabled because of a problem (usually air leaks as the unit gets older) and the PSE controller disables this so that the remaining items on the pneumatic circuit continue to work. All central locking is working fine. I have also read that removing the fuse to the PSE controller will cause it to reset. I have found the fuse location diagram in the fuse box in the boot, but there is no reference to the fuse for the PSE controller. Does anyone know where this is and which fuse it is?
Actually I think I may have a W213, I’m not sure how to edit the post title!
