btjtaylor
Hi all
I have an E350 CDI blueeff (265hp model) and my next service item is the fuel filter - it is overdue and really should've been done on the service last year (4 years) according to the service history
After having a bit of a read I can see why a lazier garage (or cheaper customer) might not bother to do it,
The main potential issue seems to be with the metal charge pipe that goes over the top of the engine. It has a resonator which is in the way of getting the fuel filter out
There seems to be 2 methods:
1 - Remove the charge pipe
2 - Loosen some bolts and maneuver the fuel filter towards the turbo and out the way (E350CDI W212 fuel filter replacement problem)
I think I will try the method without removing the pipe first as it seems others have had leaks from the o rings on this pipe after removing it (e.g. E350Cdi - OM642 Turbo Charge Pipe Leak | Engine)
If I do need up ending to remove and refit the pipe I would like to be able to renew the seals when I do it - does anyone know the part number of the seals?
I think the top side of the pipe (green o-ring) is A0289974548 but struggling to find part code for lower side
Thanks in advance
Ben
Thanks in advance
Ben
