- Mar 30, 2011
- C63 , E350 CDI, C320 CDI, SQ7
I see quite a few facelift 212s with dodgy rear lights. The ones attached to the boot are normally working but the ones on the body seem to fail . Must be a common fault.
Brilliantly helpful - what a great first post!
Welcome to the forum![]()
Hi thanks for a great post. I have the same problem on the right rear light. I have never attempted something like this but do a fair bit of DIY so would be able to do it. can i please ask once you make the holes in the plastic, do you see the broken connection between those white wires and the connectors or something else. sorry couldn't get that clear from the pictures. And is that those wires that you solder back onto those connectors? many thanks for your help and advice.There is no need to take the rear lamps a part. Here is a way how to fix them. This lamp is from LHD car and this lamp is from left side "view from behind". Those should be pretty similar in RHD and LHD cars as far as i know.
You can cut these "service holes" where you get access to these three connectors witch usually are the origin for the problem. Just solder with tin those three components and you are good to go.
I used dremel to cut those service holes and vacuum cleaner was sucking the plastic chips whole time i was cutting, inside the lamp remained clean.
You can glue the plastic peaces back on it or just use some strong tape to cover the holes.
The whole job took about 45min and i saved 350€
hi
I bought new complete W212 tail light after old one have a flickering issue (a common fault).
after instaled LEDs are working all good including right turn signal LEDs row.
the problem is that the message comes on the dash:
---The rear signal bulb needs replacement (also the sound for turning right is faster as when one of the bulbs need replacement )
- anyone know what's wrong as a lamp its brand new ordered from eBay Germany, if refit the old unit, dash message disappear ..
Does the new tail light function correctly i.e. do all the LED's illuminate?
When the original tail light failed (before you fixed it), did the car not alert you to the fact it was intermittently failing? Seems a little disappointing on a modern car that something as significant as a failed tail light wouldn't be brought to the drivers attention. My 2002 BMW 3-Series even managed this, more than 15 years ago!
Do you have a link for the Stanley hot knife, I might have to invest!
I assume you're not re-soldering the joints, you're simply briefly melting them?
