ken thomas
Can I retrofit a reversing camera to my E350 2015 W212?
As I said, all later cars need live coding - it's not a matter of cracking any codes, I'm afraid.I can`t access the engineering mode in order to activate the camera once it is all installed, has anyone cracked the entry code yet?
As suggested, I have contacted Command Online, unfortunately, they were less than helpful. Has anybody experience of this type of install....i.e. part numbers of the parts required and coding etc.
Thanks for the video link, I have viewed it and I am sure I could carry out this install myself, the problem is finding the right kit as my car is the facelift with the NTG5 head unit and the usual engineering access code ...end call+1+# doesn`t work? unless you know the latest code for these head units?Check out the video I posted as the install will be similar if not identical to that
Quite frustrating really, I emailed my VIN number to them along with a list of OEM part numbers for a complete set up that I have been offered, they declined any help on these but offered me their kit for £699 including install, or if I sauced my own kit they would charge £499 to activate it! the problem here is that I am based in the north midlands and they are down south which makes it impracticable for me to use them, so, we are getting nowhere fast.
I appreciate the cost of coding is unavoidable, however, the fact that I gave the part numbers for kit that I have been offered (A212 905 43 05) for a facelift model, a simple yes or no would have been nice. I subscribe to your video channel and find them very good and helpful, keep them coming.STAR/XENTRY Costs a huge amount per month for the licence, they will code it for you correctly and also update your VIN to reflect this (so that when even MB themselves search your VIN it will slow as an original option). added to which its a big job to fit (it took me about 3 hours alone).
I managed to source the parts myself and fit them myself + enable the option, im afraid its not possible to enable the feature on NTG-5 without having it connected to a STAR machine.
The fact they are located 2 hours away from you isnt their fault. I dont understand how you say they were 'less than helpful'?![]()
Im sorry you feel we were less than helpful.I appreciate the cost of coding is unavoidable, however, the fact that I gave the part numbers for kit that I have been offered (A212 905 43 05) for a facelift model, a simple yes or no would have been nice. I subscribe to your video channel and find them very good and helpful, keep them coming.
I have an S212 E350 Night Edition 2016 year which surprisingly did not come with a reverse camera, I travelled from Norfolk to Comand to have this retrofit, it’s done as per factory spec, the camera now shows as part of the car specification.Quite frustrating really, I emailed my VIN number to them along with a list of OEM part numbers for a complete set up that I have been offered, they declined any help on these but offered me their kit for £699 including install, or if I sauced my own kit they would charge £499 to activate it! the problem here is that I am based in the north midlands and they are down south which makes it impracticable for me to use them, so, we are getting nowhere fast.
Hi Ken,Hi Robin, thanks for your input, nothing against Command but it`s a long way to travel what with Covid restrictions etc. I have now decided to go down the route of fitting a 10.5 inch Android screen, this will upgrade my existing screen and I will then be able to fit an aftermarket reversing camera at the same time (no coding required) I can then also update my navigation maps as and when I like, ( google, waze, etc) plus quite a few extra benefits that come with this upgrade, I think this the way to go.
Regards
Ken.
