oh right ok, wouldnt it be easier just to say c200 61 plate? lol like i said im new to mercs
cheers jamesfuller
Unfortunately , no.
During changeover years that wouldn't tell you which model it was , then you have late registrations - as an example the W124 was made ( in Europe ) from around 1986 to around 1996 , give or take a year or so . However they continued to be assembled in India for a few years beyond and some were shipped back here as we are a RHD market . I had a 1999 registered W124 on a S plate , and there were others registered as late as '51 plates . Going by the model designation and year alone , most would presume the vehicle to be the W210 , which was the successor to the W124 .
Then you have imports : I also have a 1957 219 ( W105 ) which came to the UK in 1964 , hence has a 'B' registration - in that case , the model was not carried over directly to the following generation , the nearest equivalent model being the 230 W110 .
In fact , going back to the 1960's , when cars only wore their type designation badges on the bootlid , and this generally designated the engine size , you could have the same engine in different bodies , hence the Wagen number (W) identified the body type - taking the 230 as an example - you could have the plain 230 which was a six cylinder carb engine in the short nosed body shared with the smaller 4 cylinder cars : this was the W110 ; then you could have the same engine in the larger body and with twin carbs , the 230 S , this body shape was the W111 , above that you had a very similar body with higher spec and only offered with the 3 litre injected engine , the 300SE W112 ; finally , for the 2.3 L , you had an uprated and injected version in the 2 door sports car - the 230SL , which was a W113 . Hence the range of the early sixties comprised four models , with different engine options within each - the W110 , W111 , W112 and W113 - all ran alongside each other and shared years of production .
The Wagen numbers do try to run in sequences , often from the time models are developed rather than actual years of production , and sometimes unused numbers are used later - hence the replacements for the 110-112 Fintails were both the W108/109 for the larger saloons and the 114/115 series for the smaller ones . The successor to the W113 was the 107 sportscar , based on a shortened W116 platform ( this was the successor to the 108/109 , and the first model to be called the S Class - the first model to have an alphabetic type/class designation ) . After the 114/5 models ran their course , they were replaced by the W123 series , which in turn was replaced by the W124 ( the latter being designated E Class at its mid term facelift ) . Since the W125 was a pre war GP car , and the W126 was already the successor to the W116 , the next E Class jumped ahead to W210 . By this time , Mercedes had already introduced a new generation of smaller car , the 190 , designated W201 and reserved a run of numbers for that series - W202 , W203 , W204 and the current W205 have all been known as the C Class . The E Class ranges have been W210 , 211 , 212 and the S Class ranges went from W116 , W126 , W140 , W220 , W221 . The SL series started with the W198 300SL , and its smaller sibling W121 190SL , the two models being replaced by the W113 in 230/250/280SL models , then the R107 ( R designated roadster ) , R129 , R230 and R231 models .
Since my interest is really only in older cars , up to around the 80's models , I haven't bothered to keep up with more recent models , so I will leave that to someone else .
Wiki has good coverage of the various models and typing any Wagen nr in there will bring up a page of good info .
