Hi guys,
Gearbox (cls 2006 diesel 722) stucks in a mid range gear after breaking to standstill or breaking to very slow speedon angled road . If I stop again and change gear to any other position and put back to drive or rev - clutch is disengaged completely, behaves like in neutral. After stoping and starting engine again - works fine.
Happened several times already - most common scenario happens under circumstances with those factors :
1. breaking or stoping on angled down road (motorway slip road etc)
2. it doesn't matter what speed I did drive before breaking , could be 20 could be 70)
3. it doesn't mater if if its a clod start or after hour of driving
- It's not common turbo / sensors issue - I done that some time ago
- It's not batter as I just change it (hoping it will fix the problem)
- Oil changed half a year ago - no symptoms before that but that could be just timing
Do you think it's a time for electronics to be changes in gearbox?
Cheers for help
Cheers for help
