nick mercedes
Anyone ever fitted a coolbox to a W220?
I did not find them listing a coolbox for the W220 but I think they had one listed for the W221, are you referring to that part? I believe it should fit to both models. The car however has to be equipped with skibag. The coolbox attaches simply to the skibag frame, only power harness needs to be retrofitted.
But you are not supposed to purchase that part, it should be there for me, just waiting for the price to go down a bit.![]()
I've got a W220 fridge, and a W220 less fridge, I was wondering what sort of job it is to fit?
I'm not sure if I understood right, do you mean you have a W220 car that does not have the fridge and you would like to retrofit one?
The problem with the W220 is that the fuel tank is different on a car with a ski bag (or fridge), there is no room for the opening the fridge and ski bag need.
Êàòàëîã
Once the car has a ski bag, installing a fridge is simply detaching the ski bag and installing the fridge to the frame where the ski bag is attached.
NB the W221 fridge can be a bit cheaper, what did you have in mind?
Anyone ever add the fridge?
I threw it away... quite a long way in fact.
Diesel Benz said:To a W220? Don't know but I did put the fridge from Nick to my W221.
For the W221. Are you saying you took the fridge made for a w220 and put it in your W221? Or you have the w221 fridge in your W221?
Does it work well? Isn't there anything you don't like? I'd love to find a used one.
Mine is a genuine W221 fridge. I did not check it again but I think the parts numbers are after all different for the W220 and W221. One might still work in the other, even the W222 fridge looks exactly the same as the W221 fridge but comes with a different part number. It has the power wire (and socket) on the other side of the fridge, otherwise looks the same.QUOTE]
@DieselBenz, my fridge has a 3 pins powerwire but I have no socket yet so can you tell me about the 'socket' eg picture, part number which connects power plug. I assume it is a socket+harness in one, which inturn connects to the rear SAM I think. Thanks.
