design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
My car has been running fine but a few weeks back I was getting a squealing noise now and then when I accelerated, recently the sound has been more constant and when pull away or rev the car whilst driving it gets louder but some times it just stops making the noise whilst driving along and then all of a sudden it starts up again. When idle it does not make a sound but if I rev the car in park or neutral it makes the squealing noise. I have changed the belt and looking at the old bet it showed no signs of damage or wear.
I used a stethoscope to pin point the noise but it almost sounds like it from the rear of the turbo, my initial thought was the water pump as it loses 2l of water every 2 weeks but the wheels on the front of the engine all look pretty stable. the sound is almost coming from the CAT behind the turbo.
I am hoping to get a garage to have a quick look to see if they can identify the problem but hopefully someone may have had a similar problem and maybe direct me to a possible area to check. I will need to do a pressure test to find the leak in the cooling system.
W220 2001 S320cdi - 235,000miles
