Wayne Gates - Harrow
GH421
Bedfordshire
W221 S320L Cdi
My S class broke down on Saturday evening on the m25 due to an electrical failure and I needed someone who could pin point the fault without having to spend ££££££ on changing parts as most mechanics do.
Terry found the fault and fixed it with no hassle whatsoever.
Great service once again and very good value!
p.s Terry I found out what the problem was with my outside temp issue....it actually was 13.5 degrees!
What was the fault ?
The car had all the errors show up on the dash, indicators stopped working and the ignition wouldn't switch off.
Fault was a CAN connector having corrosion.
